Run Time Error 429
Hello,
I had VG ver 5.2 running on a windows 2000 server, and it wokred fine - got a virus and killed it and started having problems with VG something about the registration was not valid for this product, but it wasn't the error 429. So i unistalled and reinstalled and now all i get is the "runtime error 429" when i try to run voiceguide.
I have rebooted and reinstalled numerous times with no sucess. The uninstall process shoudl completely remove and unistall all .ocx files correct ?
Thanks in advance,
Kevin Bamonte
Runtime error 429 usually means that there is some OCX missing on your system.
I'd probably recommend you just reformat and reinstall windows from scratch. If you had a virus on your system then all kinds of other things could have happened to your machine which may not have been picked up by the anti-virus software. Best to just start with a clean slate.
Ok .... i completed wiped and reloaded the machine, installed voice guide and everything popped up fine, voice guide worked. I then installed the voice guide for dialogic patches and am back to the same error message i started with "Runtime error 429" - dialogic software won't come up at all.
Help !
